Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 04-12-2012, 10:27 AM
harryvil harryvil is offline
how to change trans fluid escape 2009
I need instruction on how to change trans fluid for 2009 AWD escape & also the filter. BTW where can I buy trans fluid mercon LV
Old 05-07-2012, 07:20 PM
shadows shadows is offline
Re: how to change trans fluid escape 2009
I have the 2008 Escape 4WD & 2009 Escape 4WD- you would be wise to purchase the "Haynes Repair Manual" #36022
basically- you remove the very lowest bolt and drain out the oil- add- run- drain-add
any automotive parts store has the correct fluid
so does Walmart
Old 05-08-2012, 09:24 AM
danielsatur danielsatur is offline
See Google ''Youtube DIY auto transmission oil change'' ,
also see www.alldata.com
How many miles are on your 2009?
Old 05-08-2012, 03:38 PM
do you have an Escape like he has- have you changed the fluid and filter
Old 05-14-2012, 04:08 PM
If it works + it's not on the maintenance schedule don't fix it!
Old 05-15-2012, 02:54 PM
is this dirrected at me or the OP
if at me- how many years have you been a transmission specialists-
Old 05-22-2012, 01:56 PM
Off_Timing Off_Timing is offline
What's the mileage on that 2009? Sounds a bit early to be changing the trans fluid. But, it's your ride.
The trans filter is deep within the tranny. Don't try and get at it. Like previously said, you want to drain, fill, run, repeat a couple of times. You do it a couple of times because draining it alone doesn't get all the fluid out. There's a lot in the torque converter that doesn't get drained.
When I priced the cost of trans fluid, and how much I was going to need, it was pretty close to what my trans mechanic would charge me. So I just got him to do it....no mess, and no fluid to dispose of (properly).
Good luck.
The Following User Says Thank You to Off_Timing For This Useful Post:
harryvil (05-22-2012)
Old 06-20-2012, 12:35 PM
Good luck.
good words- I have 2
bought 22 quarts at Walmart- serviced both- a pretty good Saturday- cost with tax-87.91
I've known a shop or 2 that puts in any old ATF
best advice- drain/add/drive,drain/add/drive
tell us of a shop that will drain/add/drive/drain/add for arround what 12 quarts and a couple hours of a bit of tender loving care to your vehicle
name the cities, business, that really will do your transmission justice- and have a reputation
also- could you give us an accurate cost of what these transmission specialists charge for a removal, dismantle, clean, rebuild, test drive, and provide a warranty for said transmission- 6 speed Auto/Overdrive
$2,700.00 seem about right-
funny- simple little afternoon at a cost of $40.00 every couple years would seem not so bad-
The Following User Says Thank You to shadows For This Useful Post:
harryvil (06-20-2012)
Old 06-20-2012, 03:05 PM
Good luck.
The mileage is 53,000
changing trans fluid, how much do i use? DEADMEAT101 Silhouette 2 02-18-2005 06:28 PM
how often do I change Trans. Fluid? Green Machine 95 Aurora 2 01-29-2005 08:41 AM
changing trans fluid, how much? DEADMEAT101 Trans Sport 1 01-16-2005 01:36 AM
How and how often should you change trans fluid? vinceleto Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 03-12-2004 06:12 PM
differential fluid change/trans fluid change sharky88 Cherokee 4 02-27-2004 06:01 AM
