Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 01-15-2005, 09:26 PM
DEADMEAT101 DEADMEAT101 is offline
Send a message via AIM to DEADMEAT101
changing trans fluid, how much do i use?
Im going to be changing the transmission fluid and filter on a 1995 oldsmobile Silhouette 3.8L 4-speed auto (4t60) and im going to drop the pan to change fluid. my question is after i drop the pan, drain fluid, intsall new filter and put pan/gasket back togethor. How many quarts of tranny fluid do i put in the tranny? (not drain torque converter, just droppin pan)
1995 Ford Mustang 3.8L AODE coupe...
1997 GrandPrix GTP 3.8L SC sedan...
coming soon 1998+ trans AM LS1...
Old 01-18-2005, 01:45 PM
redly1 redly1 is offline
Re: changing trans fluid, how much do i use?
they can usually tell you at the auto parts store. For some reason, I seem to remember buying 6 qts
Old 02-18-2005, 06:28 PM
dukeofchurchill dukeofchurchill is offline
Send a message via AIM to dukeofchurchill
When I change mine I start with 3 quarts. Then start the motor and continue to add. Usually I think I add about 9 quarts. But I measure frequently simply because you never get it all out and you will not know how much you do get out. So buy plenty and use the dip stick.
