Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-11-2012, 11:54 AM
fastinjun fastinjun is offline
2003 Venture overheated and now running rough
This is my uncles car and Im doing this for him. Its a 2003 Venture that he has had since new. It overheated but there is no water in the oil and there is water in the radiator so Im thinking that the thermostat froze not allowing water to circulate. It runs rough, makes a bit of noise from the top end. Im guessing it bent a valve or ? My question is should I go ahead and take the heads off or just find a good used engine? Im just wondering if the sleeves have been scored due to over heating, if thats the case obviously finding a motor would be the better option but Im not too familiar with these motors so what options would any of you "pros' suggest??? I have located a 3.4 out of a 2003 impala, mileage unknown so I could be getting a bad motor again.
Thanks in advance.
Old 04-11-2012, 12:48 PM
tempfixit tempfixit is offline
Re: 2003 Venture overheated and now running rough
Thanks in advance.
Welcome to AF
Can you make a video of noise and post??? What kind of noise??? A ticking or knock sound??
Do a compression and leak down test before making any hasty decisions.
Have you looked at and tested existing thermostat? Pressure test the cooling system.
Do a detailed diagnoses before throwing monwy at it, diagnoses will save you money in he long run.
Give us as much info as you can.
Old 04-16-2012, 01:03 AM
well, did a leak down test on the motor, #2 cyl is blowing air into the water jackets, not a big deal but #1 cyl there is major lose of pressure and air is being blown into the crankcase so there is damage at least to #1cyl.
Uncle wants this car running so I guess I will be looking for a decent motor...
Old 04-16-2012, 01:12 AM
Found a good motor from an 03 Impala 3.4, is this a good swap for the minivan motor???
Old 04-17-2012, 12:17 AM
phipps phipps is offline
Sounds like it overheated and blew a head gasket. Happened to our 01 Venture with the 3.4L engine.
Old 04-17-2012, 12:29 AM
It definitely blew a head gasket, #2 cyl to be exact. Number 1 cyl is blowing air past the rings into the crankcase with the leakdown test so Im guessing some sleeve damage, pity really, car is in really good shape beside that.
87 Mustang overheated, now runs rough badgurl Mustang Problem Diagnosis 3 01-10-2009 11:21 AM
Now running rough when cold after working in intake - '96 3.8L mrappe Windstar 2 10-31-2007 09:07 AM
95 Jeep GC overheated now run rough T-Dubb Grand Cherokee | Grand Cherokee SRT8 0 01-28-2007 06:07 PM
installed new fuel pump, now runs rough mthc85 SC/SL/SW 3 11-03-2005 10:06 PM
Washed engine, now runs rough ckimports Discovery | LR3 | LR4 0 02-28-2005 07:50 PM
