Old 04-07-2012, 02:45 PM
Wags391 Wags391 is offline
10-year Owner
Post Scanning with WinALDL, OBDI, 92 S10
I finally picked up an ALDL to USB cable and now have the capability to scan my ECM. Unfortunately, I don't know what all the info means. Does anyone have some experience reading ECM data and utilizing it usefully? I can even share a Excel spreadsheet with my trucks read-outs. What are some things to look for? What are normal readings for all values? What can I gather specifically about my rough idle with this information?
I have a 1992 S10 Blazer, 4.3L, TBI, 4x4.
Here's a taste of the info:
BLM- 144 at 525 RPM idle, MAP- ~35
BLM- 124 at 2000 RPM, MAP- ~62
The oxygen sensor ranges from 0 to .906. What's a good read out of an O2 sensor?
The coolant temp never got above 187.3.
Lots of info in this file.
Wags
Old 04-08-2012, 09:47 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Scanning with WinALDL, OBDI, 92 S10
Wags
Get a All Data DIY Online repair info susscription for sensor redings .
Front 02 sensors should swing from .2 to .8 volts with the average at .5volts.
Your sensor readings will depend a lot on engine load.
MT
Need to learn about Scanning with Autoxray 5000 CNCmann Engineering/ Technical 0 08-28-2009 01:34 PM
First scan with my new scanner DP_Design Sketching and Drawing 15 03-05-2006 12:54 PM
HELP with a 91 S10 Blazer trany good_and_muddy S-10 8 09-13-2005 12:04 AM
4x4 Porblems with my 91 s10 blazer!!!!! Ssincere Blazer 7 09-24-2004 02:37 PM
i need help with my 94 s10 4speed gotaprob S-10 2 09-19-2004 02:09 PM
Tags
aldl , data , idle , obd1 , winaldl
