Old 09-06-2005, 10:14 AM
good_and_muddy good_and_muddy is offline
HELP with a 91 S10 Blazer trany
I took my Blazer through a good mud hole yesterday and let it sit for a while after I got it out. When I went to leave it would not shift out of first gear. Ohh and by the way it is an automatic. Does anyone have an idea what could be wrong with it???
Old 09-06-2005, 10:47 PM
OverBoardProject OverBoardProject is offline
Banned
Re: HELP with a 91 S10 Blazer trany
Full of water possibly
Check the dipstick and see if it's too ful.
Remember that you have to run it to check the trany fluid
Old 09-07-2005, 12:42 AM
Yeah I checked all that and it is fine... I was wondering if any one knew if I have an electronic tranny or if it works off the old vaccuum lines.
Old 09-07-2005, 12:58 AM
Banned
Sorry but it's electronic
The electronics appear to be pretty well sealed though, but you might have knocked a plug off or something.
Is there any reason why you left it parked there? besides possibly being stuck
The reason why I'm asking is because if you had a break down it might be related.
Old 09-07-2005, 05:05 PM
I had to let it sit to help my buddy work on his Jeep. It didn't set in the mud the whole time... It sat after I got it out. Before that everything was great. Check oiut this website and you can see the fun we have.
http://www.geocities.com/kymudslingers/sept5.html
as you can tell I am the only Blazer there.
My friend was telling me that there is a cable that attaches to the Throtle Body that controls the trany as well... Do you know anything about that????
Old 09-09-2005, 10:42 PM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
It's called a detent cable. All that really does is tells the trans when the throttle is open to a certain point and to drop it down a gear as if you were passing. Water shouldn't have done anything to that.
Old 09-09-2005, 10:49 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Check your VSS connection on the tail shaft of your tranny.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-12-2005, 09:39 PM
Vortec350S10 Vortec350S10 is offline
That detent cable is the TV cable and that and the governor are the 2 things that "tel" thel tranny what your vehicle is doing. Governor- tailshaft speed, TV cable-throttle position. THe TV cable does not only determine when it downshifts, it also controls line pressure which affects shift firmness, torque convertor lock-up, and obviously upshift points too. This is only if you have an older truck (92 or older) with a 700r4. 93's and newer have a 4L60E (if it's a 4.3) which is physically the same as a 700r4 but is electronically controlled. It would help a HUGE deal if anybody who has a question would tell everything they could about their truck like the YEAR,ENGINE,2 or 4WD, MANUAL or AUTOMATIC, and any options it might have if they have any relation to the problem.
and yeah I realize you have a '91.
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Old 09-13-2005, 12:04 AM
gstark76 gstark76 is offline
does it have a vaccume line on it to the modulator? If it does this could have been pulled off and it wont shift out of 1st.
