Old 04-07-2012, 02:15 PM
imamacanac imamacanac is offline
Send a message via MSN to imamacanac
41te Caravan Trans.
Hello! Is it possible to remove the diff without dropping the transaxle?. Any feedback would be awesome. Thanks.
Old 04-08-2012, 05:31 PM
jamesslcx jamesslcx is offline
Re: 41te Caravan Trans.
Probably not. Someone correct me if I'm wrong.
Old 04-08-2012, 05:56 PM
tempfixit tempfixit is offline
What year vehicle???? Engine????
I have had the cover off on a 95 voyager to inspect ring gear and bearing, I would investigate to see if removing trans mount would allow trans to lower enough to remove ring gear, You will still need to remove both halfshafts.
You need to remove tire and a protective plastic cover if I remember correctly for access to cover on basck side of transaxle.
Old 04-09-2012, 06:11 AM
1998 Caravan 3.0 liter.
Changed trans fluid in 98 Grand Caravan & added Trans X fluid to help leak,is this ok lindseylu Caravan | Voyager 6 01-06-2007 01:45 AM
Changed trans fluid in 98 Grand Caravan & added Trans X fluid to help leak,is this ok lindseylu Engineering/ Technical 3 01-06-2007 01:08 AM
94 Caravan trans sticks in gear enginereplace Caravan | Voyager 1 01-14-2005 05:56 PM
97 grand caravan trans oil w8ezl Caravan | Voyager 1 12-02-2002 12:40 AM
