Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 04-06-2012, 02:52 PM
tlijun tlijun is offline
Lincoln LS Brake Push Piston Back Problem.
I am replacing my Lincoln LS 2004 rear brake, and borrowed Disc Brake Caliper Tool Set from Autozon, but the Piston cannot be pushed back.
Can someone tell me the correct way to push the piston back?
Thanks you help in advance.
Old 04-06-2012, 03:33 PM
joegr joegr is offline
Re: Lincoln LS Brake Push Piston Back Problem.
The rear caliper pistons have to be screwed back in clockwise while applying pressure. This tool set will do it.
http://www.harborfreight.com/18-piec...kit-97143.html
Note that when you are done, the piston has to be left turned to the correct orientation to mate with the back of the brake pad.
Old 04-14-2012, 08:45 AM
Thanks Joegr. It worked by screwing back in clockwise while applying pressure. The rear brake pads were changed.
Hissing sound coming from brake pedal Badman123 Navigator 0 06-06-2011 03:29 PM
no brakes after lubing slides and pushing pistons back revyurengine F Series 5 05-05-2011 12:59 PM
Brakes-Can't get piston back in caliper sallanblock Pick-Up 17 09-11-2005 07:45 AM
Halo 2 pushed waaaaay back... BP2K2Max Other Games 6 10-01-2004 08:24 PM
what years had what brakes? 4 piston or 2 piston TEAM KLR '94 - '01 0 11-20-2003 04:30 PM
