Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-06-2012, 01:07 AM
Vilaman Vilaman is offline
2000 V6 Camry trans/diff fluid questions
I want to change the transmission and differential fluid in my 2000 V6 Camry. Are there separate drain plugs? How much fluid comes out when drained?
Old 04-06-2012, 09:00 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2000 V6 Camry trans/diff fluid questions
Yes, there are separate drain plugs. The capacity if only drained is around 4 quarts.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-15-2012, 04:19 AM
Do I have to fill each separately, or can I just fill the transmission and it will flow in to the differential?
Old 04-15-2012, 01:21 PM
artbuc artbuc is offline
Fill through the trans dip stick and it will overflow into the differential. Interesting that the FSM says to fill the differential separately but I have never heard of anyone finding a separate fill plug.
Old 04-15-2012, 08:02 PM
Brian R.'s Avatar
Resident Chemist
There is a separate fill plug on the differential. I have used it, and you have to use it to fill the differential to the proper fill height.
Old 04-16-2012, 09:08 AM
Holey Moley! Is this something new on the 2000 models? I thought only the 4 cyl models had a separate differential fill plug?
Old 04-16-2012, 01:34 PM
Brian R.'s Avatar
Resident Chemist
There is no way of telling, but all the Gen 4 v6 I've paid attention to have them. I've only seen a couple.
'94 Camry to flush trans or not? crackedvenom Camry/Camry Hybrid/Vista 12 11-24-2010 06:40 PM
2000 Toyota Camry Rebuilt Transmission Computer Problem gujuchokra Camry/Camry Hybrid/Vista 5 08-20-2009 08:45 PM
98 camry trans fluid suggestions olderthandirt Camry/Camry Hybrid/Vista 5 11-14-2008 03:33 PM
Help with trans/diff fluid swaps... stupid procedural/tool questions (PICS) Cobra4B GTRA / GTWS / GTS 2 01-23-2008 12:03 AM
diff. fluid change question johnsm Rodeo | Passport | MU 3 10-26-2005 04:55 AM
