Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-17-2010, 12:03 PM
crackedvenom crackedvenom is offline
'94 Camry to flush trans or not?
So i bought a used camry and i dont know what has been done to it. So im fine tuning it, changing fluids, flushing, just a little maintenance. It has 170,xxx miles on it and i have no idea when the last time it was done. Ive heard that changing it at high miles could be bad. Since i just bought it, i would rather it continue working for a good amount of time. What do you guys recommend?
Old 11-17-2010, 03:20 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: '94 Camry to flush trans or not?
I recommend just what you are doing, changing all the fluids, so you will now have a baseline with which to work. I would include the brake fluid too, although you can take a look at the brake fluid to see how dark it is, and judge from that on whether it needs replacing,
I would advise against having the transmission flushed using one of those flush machines, at your mileage. Just drain the fluid out and drop the pan and change the filter. Put everything back together and refill the trans fluid. Drive the car around 500 miles and then do just the drain and refill portion again. I would then drive another 500 miles and do the drain and refill one last time. That should ensure the you have mostly new fluid in there.
The other thing I would do would be to replace the timing belt, so you will have a baseline on that too. The recommended change interval for the belt when your car was new was every 60,000 miles. I think you are now safe using a 90,000 mile change interval as was recommended with the generation 4 Camry (1997-2001).
Mike
Old 11-17-2010, 04:03 PM
Originally Posted by Mike Gerber View Post
I recommend just what you are doing, changing all the fluids, so you will now have a baseline with which to work. I would include the brake fluid too, although you can take a look at the brake fluid to see how dark it is, and jusge from that on whether it needs replacing,
Mike
Mike
Great! Thanks for your lengthy reply Ill check the other things i havent yet when i get a chance.
One more question if i may. There seems to be kind of a metal against metal type noise coming from the front. I hear it could be the brakes going bad, which seems logical since i have to press em down a decent amount to stop. Ideas?
Old 11-17-2010, 04:11 PM
Scrapper Scrapper is offline
AF Premium User
plus when changing run a magnet threw old fluid to check for metal shavings there will be some but cant have chunks of it. and if you change timing belt change water pump because pump go's bad you'll have to tear it back down because pump is behind timing belt. those toyota's are good moters.
Old 11-17-2010, 04:15 PM
And thank you. I will get these done on a day when its nice out again.
Old 11-18-2010, 09:05 AM
AF -Advisor
"One more question if i may. There seems to be kind of a metal against metal type noise coming from the front. I hear it could be the brakes going bad, which seems logical since i have to press em down a decent amount to stop. Ideas?"
If this noise is happening only when the brakes are applied, it could indeed be the brakes. Most brake pads have what's called a pad wear indicator on them. It is simply a metal tang that contacts the rotors when the pads wear to a certain level. This level is close to the end of the useable life of the pad material. As the brakes are applied and this tang makes contact with the brake rotors, it makes a loud screeching sound. If this is what you are experiencing, have your brakes checked out as soon as possible, or check them out yourself if you feel you are capable of doing this. Many places offer free brake inspection. I think Pep Boys is offering this free service right now with a coupon printed from their website.
Mike
Old 11-18-2010, 12:55 PM
AF Premium User
yah i call it the warning signal so you don't fry your rotors.
Old 11-19-2010, 12:05 PM
thanks. can someone tell me where the pcv valve is on my camry? i want to check that while im at it. i dont have a picture handy but this looks pretty similar to mine.
Old 11-19-2010, 12:18 PM
AF Premium User
should be sticking in top of valve cover and when removed if it rattles when you shake it don't need replaced unless you just want to.
Old 11-22-2010, 02:27 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Usually on the driver's side end of the valve cover, with a short tube conecting it to the intake plenum (the big part labeled "EFI"). It's pressed into a rubber grommet that may be hardened from all the years/miles, so be careful you don't crack the grommet and allow pieces to fall into the valvetrain underneath it, though there are some metal baffles in the valve cover to keep any foreign crud contained.
Better yet, buy a new grommet and replace it. I had to pull my old one out a piece at a time, being careful to not let anything drop down.
As scrapper said, it should rattle freely when shaken but should only let gases go from the valve cover to the plenum. Use compressed air to test this.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-24-2010, 07:37 AM
jalopyjoe jalopyjoe is offline
I couldn't help but to call around to find out how thin my wallet would be if some else got dirty changing the filter and all. Of course I knew they would push for the flush. But as he was throwing me the sales pitch, he said something I need to ask here.
He said he would flush the tranny first. Then after, drop the pan & change the filter.
My question is, if he flush first then drop pan, wouldn't that drain out the gunk from the flush? Or does most still stay inside until it's driven?
98' S-10 4x4- Nice Truck
92' Previa
Now a 99' Camry
Old 11-24-2010, 08:40 AM
jdmccright's Avatar
The RustBuster
Filters work one way. The tranny sucks in fluid from the pan through the filter. When they flush it, they can do it in either normal or reverse flow. Normal flow you're still pushing fluid through an old filter and any contaminants or sludge buildup that has formed past the filter are dislodged and pushed even further into the tranny. But if they use a reverse flow flush, some of the trapped contaminants in the filter can be pushed back out into the fluid, plus the aforementioned dislodging of buildup. The critical area is the valve body (that hunk of aluminum just inside and above the pan)...gunk in the wrong places there can ruin a tranny. If they are somehow able to bypass flow away from that, then I'd almost say okay.
It is not that you don't want to remove the buildup, it is that you need to remove it in very tiny pieces so as to not affect anything else. Power flushing can result in comparatively large pieces being dislodged whereas the multiple fluid change method allows it to be redissolved.
Let's be clear on one point: a power flush is not recommended on a tranny that has already been neglected. Many owners are remorseful about their "sin" of neglect and think that by opting for the flush it will undo all the wrongs...it won't. However, for a car that's been maintained regularly, a flush will likely be harmless since there is a low chance of having any significant buildup.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 11-24-2010, 06:40 PM
Ok. I think I get it. There would still be some large particles probably floating around somewhere inside because it was large and wasn't able to flow out from the flush. This in turn would mess it up later on.
92' Previa
Now a 99' Camry
Do It Yourself ATF Flush Techniker Engineering/ Technical 3 07-07-2010 12:55 AM
too flush or not to flush duke1992lx Ram Pickup | Ram SRT10 2 11-30-2008 04:53 AM
Flush or not to Flush? jacuzzo Intrepid 7 12-16-2005 11:00 PM
'94 Camry engine stumbles and dies when car switched into gear and not moving unbreakable23 Camry/Camry Hybrid/Vista 5 07-07-2005 10:10 PM
Changing coolant: to flush or not to flush. mjlabas Corolla/Matrix/Voltz 1 09-04-2004 04:20 AM
Tags
change , fluid , tranny , transmission
