Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 04-05-2012, 10:30 PM
21sprint 21sprint is offline
2002 4.7L Dorango rocker arm problem?
I have a 2002 Durango, the #3 Exhaust rocker arm keeps coming off, it was took back to car lot and they installed it. It lasted a day, now the shop has replaced rocker, and lifter, changed oil to 5W-30 and tried another camshaft. It starts and runs but by the time you get a block it starts again. The old cam was worn on the same #3 cylinder but we think driving it with arm off caused the damage. The spring feels still when we try pushing it down with a prybar, can a spring be changed on the vehicle?
Old 04-06-2012, 05:00 PM
jamesslcx jamesslcx is offline
Re: 2002 4.7L Dorango rocker arm problem?
21sprint, yes the valve spring can be changed still on the vehicle. Odd problem.
Old 04-13-2012, 09:56 PM
Not just odd but pretty hard to repair without buying the valve spring tool needed. The cam had a bad lobe on same cyl. so I tried that 1st but still kicked off rocker. I put air on the cyl. and valve spring was weak, but that wasn't the problem, the valve stem was bent. I was told not to try and staighen it but did it anyway, runs fine now. Lesson learned..
92 Lumina rocker arms noisy acarinneed Lumina 6 02-01-2012 10:26 AM
2002 4.3 chevy start up problem cnk2002s10zr2 S-10 1 12-28-2011 03:45 AM
Need help with 4.7L -2000 dak McCowan Dakota 1 11-08-2010 11:15 AM
Dodge Ram 2002 4.7L alqatami Ram Pickup | Ram SRT10 0 03-18-2007 04:16 PM
96 Olds Ciera SL Rocker Arm Problem dk05 Cutlass Series 3 12-14-2006 12:54 PM
