Old 04-04-2012, 03:36 PM
dapopes's Avatar
dapopes dapopes is offline
97 3.8 5 speed clutch fluid leak!
My bright purple metalic 97 is leaking the clutch fluid, but i cant pinpoint the leak! the line is dry, the floor board and pedal is dry, yet the resivour keeps goin dry! has anyone ever seen it leaking from anywhere else besides where i previously mentioned?
Old 04-04-2012, 05:29 PM
DeltaP DeltaP is offline
Re: 97 3.8 5 speed clutch fluid leak!
How about the other end... the slave cylinder itself !
Old 04-05-2012, 05:55 PM
dapopes's Avatar
I found today that its dripping at a pretty fast rate from the front of the bell housing by the flywheel. Is that where the slave cylinder is? Is the slave cylinder at the end of the braided line? And how do I access that to stop the leak?
Old 04-06-2012, 04:46 AM
dapopes's Avatar
Can anyone tell me if a leaky slave cylinder is a common prob? When they go out do they start eaking and quit workin? Or is there a seal in them that goes bad? Is there an o-ring where the line connects to it that leaks? Thank you for any answers!!
Old 04-06-2012, 05:12 PM
Fairly common problem. You can usually pump up a bad slave cyl a coupla times to catch gears without grinding. Like "double clutching" an 18 wheeler transmission. Fluid starts to by-pass the worn seal on the piston in the slave cylinder. My experience has been to replace both the slave and the clutch master cylinder at the same time. It wont be far behind and will fail soon. The worst thing to do to a hydraulic clutch is to "ride" the pedal. That not only puts wear on the hydraulics but also the clutch release bearing.
Old 04-09-2012, 10:52 PM
dapopes's Avatar
Thanks for the response! It's definitely leakin @ the slave! I'm contemplating puttin a new one on myself. Thought I might as well put new clutch, pressure plate and look @ the flywheel for excessive wear. I'll do the master too. I've never done it before, so I'm pretty nervous about it! I'm doin it in a rock/dirt driveway, so not the most convenient! The top bolt on the tranny looks impossible to get to!!
Old 04-10-2012, 12:49 AM
Cut up some plywood squares to put under your jackstands. Or get a cheap sheet of plywood to drive up on. That way you'll have little problems using a jack under the transmission. HTH
99 LeSabre 3800 3.8 coolant leak? Head gasket? Lower intake gasket is leaking.HELP!! chubbygoatboy LeSabre 10 01-03-2010 09:49 AM
clutch fluid leak X2Xtreme360 3000GT/Stealth 24 02-07-2007 02:16 PM
Clutch fluid leak question fadeaway Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 10-19-2004 10:46 PM
