Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-27-2012, 07:57 PM
lnewcomer lnewcomer is offline
2002 impala electric door locks
My 2002 impala electric door locks stopped working. I have checked the fuses, and checked the votage at the doors, it seems to be fine. The key fob doesnt work, the shift doesnt lock the doors , and they dont unlock in park, and the toggle switches on the front doors have no effect. I have a Hanes manual, but the schematic doesnt match the color coding for my car,( they say "orange" I have "black and orange", they say "tan" I have "black and white".
Can any one help?
Thanks in advance
Old 04-01-2012, 08:40 PM
la1's Avatar
la1 la1 is offline
Re: 2002 impala electric door locks
i don't think it is wiring if they all do not work. might be the BCM. The door lock signals originate from the BMC. If it is wiring more lilely from the PCM to the BCM. The BCM is right under the steering wheel colum, you have to take off that peice of plastic that goes across the has the curtosy light on it....make sure all the connectors are on.
Old 09-27-2012, 11:58 PM
barty barty is offline
Just curious if anyone has a good solution for this as my 2002 impala just started exhibiting the same thing. One exception mine is somewhat intermittent. Sometimes shifting it in and out of park will get it working and sometimes shifting in and out of park door locks won't work either. But if they don't unlock with the Key fob they won't unloac with the door switches either. I have power at the fuse the whole time wiring seems all good. Is this likely the BCM? If so is does this need to be replaced by the dealer?
Old 09-28-2012, 02:39 PM
Tech II Tech II is offline
As la1 said, your only recourse is two things.....disconnect the battery cables(negative first), and then disconnect the harnesses to the BCM....check for corrosion or loose connections(perform drag test).....if ok, with both positive and negative cables disconnected, hold the ends together for one minute.....this helps to reset all modules......
Now reconnect the battery cables, attach pos first...now operate your door locks......
Sometimes just disconnecting and reconnecting, can solve the problem....if it lasts for just a short time, it's possible it's a connection that just barely passed the drag test.....otherwise it's the BCM.....Usually a "U" code(communication) is set.....unfortunately, if you need a new BCM, they have to be "programmed" by a GM dealership....
Old 09-29-2012, 08:09 AM
Thanks I will try that and get back.
Old 10-01-2012, 07:32 AM
Updated status: Disconnnected battery cables, removed BCM (to left of brake pedal) Disconnected conectors and inspected. BCM looks good, wiring looks good, and PIN's are all fullly seated and engaged in connector no corrosion all looks like it just came off the assembly line. I was not able to do a drag test as I did not have the proper size Pin to insert and test. I reconnected BCM and then Battery so far so good door locks are working fine. If problem reappears I will update otherwise consider it resolved.
04 yukon xl driver door instrument panel problems kminton85 Yukon 0 01-09-2010 10:57 PM
02 celica electric door locks locking & unlocking by there self Jeepjones85 Celica 0 09-29-2008 09:37 PM
2002 Impala Security/door locks builder604 Impala | Impala SS 0 06-02-2007 10:10 PM
Electric Door Lock Install rednec Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 05-14-2004 12:04 AM
Disable Electric Door Locks? Fritz The Cat Lumina 0 04-19-2003 05:20 PM
