Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-27-2012, 05:18 PM
debt debt is offline
03 dodge 1/2 ton-water problems
My 03 dodge is lossing water and runs hot about every other day. The radiator front is wet but can not find where the water is coming out from-any suggestions?
Old 03-27-2012, 07:51 PM
jamesslcx jamesslcx is offline
Re: 03 dodge 1/2 ton-water problems
debt, maybe a pinhole radiator leak but if you can't find it by looking try to get a radiator pressure tester, hook it up to the radiator neck and pump up the pressure and watch for leaks. Have you looked for the leak while the truck is hot and running? Make sure you keep it full of coolant and don't let it get hot.
The Following User Says Thank You to jamesslcx For This Useful Post:
debt (03-27-2012)
1994 dodge 1/2 ton pickup 318 eng rwgclg Ram Pickup | Ram SRT10 2 01-22-2011 05:23 PM
1983 S-10 1/2 ton running problem Bobandbadger Problem Diagnosis 1 06-14-2009 06:04 PM
1999 Dodge Intrepid 2.7 water pump AVSoCal Intrepid 1 10-03-2006 05:54 PM
1985 Dodge Caravan 2.6L vacuum problems kam579 Caravan | Voyager 2 11-08-2004 08:38 PM
