Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 09-27-2006, 12:26 PM
AVSoCal AVSoCal is offline
1999 Dodge Intrepid 2.7 water pump
Can somebody tell me where the water pump is located on a 1999 Dodge Intrepid 2.7 liter engine? Thanks
Old 10-03-2006, 05:54 PM
dennis1960 dennis1960 is offline
Re: 1999 Dodge Intrepid 2.7 water pump
The water pump is an internal pump. It is driven by the timing chain, which also drives the duel overhead cams. (I just replaced mine, which, I will NEVER do again...too much work) I was lucky though, when the pump went out, it did not cause any other damage. Usually, when the pump goes out, it causes the cams to jump time, which inturn causes the valves to jam themselves into the pistons, which pretty much destroys the engine.
Good luck!
