Old 03-27-2012, 12:28 PM
ken_man_1 ken_man_1 is offline
2000 K3500 7.4L Hard start
Checked fuel pressure, it's at about 62 cold
Will crank like normal, start - stop. Runs for less than a second. After a few tries, let it sit for a few minutes, it will start right up.
Tuned about 7 months ago, only 2500 on the tune.
Not sure what next, there are no codes. Any ideas?
Thanks for looking and thinking!!
Old 03-27-2012, 08:18 PM
j cAT j cAT is offline
Re: 2000 K3500 7.4L Hard start
when the engine starts and quickly stalls this is usually the security system. key/bcm issues etc..
turn the key to ignition on engine OFF for 10 minutes. then turn key to OFF.
this may reset the key/vehicle communication. then try to start . if it continues to start normal, after this proceedure you are lucky.
The Following User Says Thank You to j cAT For This Useful Post:
ken_man_1 (03-28-2012)
Old 03-28-2012, 08:16 AM
The truck doesn't have a chipped key, I'm more than sure.
Some days it will do it, most of the time it won't. Very very intermittent.
As a maintenance issue (I don't drive the truck myself), what can I do to resolve it? I'd rather spend a few bones permanently repairing the problem than letting it go with a crew and it being unreliable
Thanks again j cAT.
Old 03-28-2012, 10:27 AM
Thanks again j cAT.
some 1990's vehicles had a visible resistor in the key. then this was changed where the key head which is much larger , this then has a device that comunicates with the BCM. if you have a security amber light then this is the pass lock system. try what I stated before and post back what happened.
Old 03-28-2012, 01:34 PM
Will do. I have had spares cut for the truck in the past, they were for sure NOT pass lock keys. These are the narrow keys. However, even the narrow keys can still be pass lock, I know. They're usually labeled PK3 or something to that effect. Let you know tomorrow.
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 02:17 PM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 08:28 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 03:26 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 06:44 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 09:52 PM
