Old 03-26-2012, 06:16 AM
asajulian asajulian is offline
Help! Won't start and no dash lights after radio install!
I just installed an aftermarket stereo in my 2001 Alero. I did not use a wiring harness, but I just cut the old harness out. (probably a bad idea!) I did NOT disconnect the battery when I installed it.
1. I did not know where to put the radio ignition wire for the stereo (the ACC wire) (it was orange in my case). It looks like this car does not have one? I ended up just plugging the radio's ignition wire into the constant hot so the radio is always on.
2. After hooking everything up, the car does not start, it turns over for about 2 seconds, then it quits. Also, the instrument panel lights are not coming on. Everything else seems to work OK, interior lights, etc. I checked the fuses IPC/HVAC BATT and IPC/BFC ACC and they are not blown. My guess is that I did not wire the ACC part correctly...
What did I do wrong? I hope it isn't some complicated anti-theft mechanism.
Old 03-26-2012, 12:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Help! Won't start and no dash lights after radio install!
Being as you DID NOT disconnect the battery before you hacked the wiring harness, the first thing you need to do is check ALL the fuses to make sure you did not pop one, or more. Alway use a adapter harness when avalilable. The radio also has (had) a serial data line to it for comunication to other modules, with that now being cut, it is causing problems also.
Old 03-26-2012, 10:48 PM
ricebike ricebike is offline
did you splice those wires correctly?
http://www.modifiedlife.com/2001-old...iring-diagram/
http://www.justanswer.com/oldsmobile...m-factory.html
1996 SL2 Won't Start - Electrical - Dash Lights Go Out jrandallc SC/SL/SW 3 10-10-2009 05:13 PM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
95 S10 Blazer won't start no dash light comie on unidraggon Blazer 5 08-27-2006 02:14 AM
'97 Jimmy cranks, won't start, no dash lights uhpitbull5 Jimmy 6 03-17-2006 05:23 PM
No dash lights after radio install? mojorison_75 Cherokee 1 10-27-2003 09:53 AM
Tags
radio , starting
