Old 03-25-2012, 09:46 PM
CL16Sailor CL16Sailor is offline
Cool Relay noise after changing front pads?
Hi all, I've gone thru the past posts, and it looks like this is a new one.
I changed the pads and rotors on my 2002 Grand Caravan today. A bit of fluid leaked out of the master cylinder tank when I compressed the first caliper (left side). After completing both sides, I started the van and noticed a loud relay click every time I pressed the brake pedal while in Park. In R, N etc the noise goes away. No indicator lights go on with the relay. The van stops fine and the brake fluid level seems fine.
Thanks in advance for your suggetions!
Old 03-26-2012, 07:43 PM
jamesslcx jamesslcx is offline
Re: Relay noise after changing front pads?
CL16Sailor, just a guess but could it be the shift interlock relay? Maybe not the right name but it keeps the driver from shifting out of park until the brake pedal is pressed.
Click noise when braking after changing front axle willowbrook Odyssey 3 01-30-2008 03:48 PM
Clicking noise when braking after changing front axle willowbrook Engineering/ Technical 6 11-15-2007 11:07 AM
brake noise after changing pads detroitrockcity Passat 0 09-30-2006 08:56 PM
Changing front pads & cutting rotors Silver Blue '97 Aurora 4 03-02-2004 01:59 PM
Changing front pads and rotors on 6th gen... SilverY2KCivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 10-31-2002 06:12 AM
Tags
brakes , caravan , noise , relay
