Go Back   Automotive Forums Car Chat > AMC/Rambler/ Nash/IH > AMC
Old 03-25-2012, 07:14 PM
bcarafello bcarafello is offline
74 AMX Oil filter splits open need fix
I have a 74 Javelin AMX. It has not run since 87. changed the oil put a new filter in. Got it to run and the oil filter splits at the seam under pressure. Need help.
Old 03-25-2012, 11:12 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 74 AMX Oil filter splits open need fix
Oil pressure relief valve is probably rusted shut. It's an easy fix to free up providing you can get to it. Usually its part of the oil pump assembly inside the oil pan.
Old 04-24-2012, 07:48 PM
big white bufflo big white bufflo is offline
the oil pressure relief is just obove the filter assembly on the pump asaembly it a large nut spin the nut out pull the spring and little valve out of there clean it and put it back toghther
Old 02-06-2025, 12:19 PM
MariaJose's Avatar
MariaJose MariaJose is offline
It sounds like the oil filter might be faulty or there could be too much pressure. Try replacing the filter with a high-quality one and check the oil pressure, as it could be too high. If the issue persists, a mechanic might need to inspect the oil pump or system.
2001 Series II 3.8 v6 blowing oil filters - fix mikesmith20001 Regal 4 04-28-2008 06:25 PM
Sonny Boy's '94 6 Cyl Oil Filter Adapter Leak fixed McCann Cherokee 2 09-18-2006 10:27 PM
Need Oil And Oil Filter Recommendation SOLSTER Rodeo | Passport | MU 9 11-18-2004 02:12 PM
new axles when boots have split open kirkmanjr Sentra | 200SX (USDM FWD) 1 12-19-2003 06:28 PM
