Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 12-11-2003, 02:45 PM
kirkmanjr kirkmanjr is offline
Question new axles when boots have split open
Does anyone know if axle boots can be replaced without removing the axles? I took my 93 Nissan Sentra in for servicing, and the mechanic showed me the boot at each front axle. Both had split, and he stated that the split would allow the grease to fall away from the axle eventually causing the axles to break. He said the only way to fix the boots were to replace them, and that required removal of the axles. The bottom line was they suggested replacing the axles also since it would only cost an addl. $80 for new lifetime guarantee axles.
Was I taken?
Thanks,
Leon Kirkman
Old 12-19-2003, 06:28 PM
mreff mreff is offline
Re: new axles when boots have split open
ummm... no. If your boots were split open your probably already caused some damage. Besides, if this is a car you drive aggressively, It's not worth the worry, just replace them every so often. If you're concerned about price buy a chiltons and to it yourself, it's not very difficult in most FWD
