Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 03-24-2012, 07:23 PM
timmy2 timmy2 is offline
1979 ford fairmont engine light help!!!!
I have a 1979 ford fairmont with low original mileage. It only has 63,000 miles. Recently the engine light came on. when i first start the car it revs very high for about 1 minute then it kicks down to normal idle. The gas milage is not very good and i think that may be a clue to the problem. When i drive the car i can smell gas but i replaced all the gas lines and it has no leaks. The engine light came on shortly after i replaced the spark plugs the wires the cap and the roder. It has a minor oil leak also. Any ideas what the engine light is trying to tell me.
Old 03-25-2012, 02:08 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 1979 ford fairmont engine light help!!!!
Timmy , try going to a Ford Fairmont specific site such as http://vb.foureyedpride.com . There are others sites as well - do a Google search for " Ford Fairmont forums " and others will come up - good luck !
" Sometimes I grow so tired "
Old 04-01-2012, 01:08 PM
joemffields joemffields is offline
sounds like your getting to much fuel or your not getting a good seal between your intake manifold and carb. previous owner could have changed the jets in the carb, intake mani got to much carbon build up or not getting enough air through the carb
Old 04-01-2012, 01:37 PM
DeltaP DeltaP is offline
Sounds like the choke is stuck and you have a vacuum leak.
Old 06-04-2012, 05:59 AM
Jeff Collision Jeff Collision is offline
Look at the valve cover, there might be leakage in PVC valve. If so, change the PVC valve. It could also be a reason for engine light is indicating you that problem.
2000 Ford Taurus engine light.... wire2power Taurus | Taurus Wagon 2 03-09-2012 01:34 PM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 04:06 PM
Tags
engine , fairmont , light
