Old 03-24-2012, 09:48 AM
Prof_h Prof_h is offline
Fuse VS Circuit Breaker '97 PA
Hi Members,
Can anyone answer this question...What is the difference between a fuse and a circuit breaker? I have located the circuit brkr for my drivers seat and was wondering if I could replace it with a 25A fuse? I don't want to just do it, as I am a little leary of electrical things and don't want to blow something else. I've lost all function of my driver's seat. It is stuck in the all-the-way back position.
Any help would be appreciated. The part number to the circuit breaker is...12088575, 25A, 14.5V
Thank you,
Prof H
Old 03-24-2012, 11:53 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Fuse VS Circuit Breaker '97 PA
You could replace the circuit breaker with the same rated fuse, but if the circuit overloads again, it will blow the fuse & require replacement. Circuit breakers reset automatically once cooled down, but the circuit breaker will eventually have higher contact resistance than it had when new. This is especially true if the breaker has been tripped (by overcurrent) more than a few times. Only you, can decided what you want to do.
The Following User Says Thank You to HotZ28 For This Useful Post:
Prof_h (03-31-2012)
'77 Dodge M880 Electrical Problem - Headlights / Circuit Breaker NoahsPa Ram Pickup | Ram SRT10 3 02-13-2006 06:24 PM
Power lock fuse/circuit breaker (87) joedogg Town Car 1 11-11-2004 03:50 AM
Power window circuit breaker mystermathers 3 Series 4 10-14-2004 02:23 PM
Please help! Window circuit breaker Tom Crippen 3 Series 15 08-26-2004 11:29 AM
circuit breaker for door locks, sunroof, etc. jdriscoll Jetta/Vento/Bora 1 02-01-2004 03:33 PM
