Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 10-29-2004, 09:24 AM
joedogg joedogg is offline
Power lock fuse/circuit breaker (87)
Okay, so my power locks went out the other day, took the power seats with it. I determined it was the fuse. I look in the manual and it turns out that its not just a fuse its a curcuit breaker (I think, its larger than a fuse, metal and has two prongs on the bottom just like a fuse). Anyway removing it and putting it back fixed the problem, temporarly (it does every time temporarily). After resetting it the second time I went to take it out when it failed again and it was so hot it literally burned me. Is it that I need a new circuit breaker, or is it likely there is a bigger problem. I should probably note that when it happened the first time my idiot friend and I were entering tons of random numbers on the keypad cause we're idoits and looking for cheap comedic effect. Thanks.
Old 11-11-2004, 03:50 AM
ltdltc ltdltc is offline
Sounds like you have a short, you may want to check the wiring.
Richard
1995 Lincoln Town Car Signature Series
Past
1992 Lincoln Town Car Cartier Designer Series
1992 Lincoln Town Car Executive Series
1990 Lincoln Town Car
