Old 03-23-2012, 07:04 AM
ecrumb ecrumb is offline
Question Squeaking pulley/belt, intermittent. 1999 Grand Caravan
1999 Grand Caravan has an intermittent squeak that I can't find. I've replaced the power steering pump three times via life time warranty, thinking that the replacement was defective. I've replaced the A/C compresser twice and the Alternator with a new one. I've replaced the Idler pulley twice, the tensioner assembly twice and the tensioner pulley with one used and two different brand new ones. I've replaced the serpentine belt once and all of this within the last ten months, with no success. I replaced the water pump about a year and a half ago, so I don't believe it could be that. Finally, the noise dissipates when I spray WD-40 type lub on the alt/PS pulley areas, but returns within ten to fifteen minutes of running. Can anyone help out there? I'm fresh out of ideas and will check any and all new ones.
!!!!!! HELP !!!!!!
Old 03-24-2012, 06:06 PM
jamesslcx jamesslcx is offline
Re: Squeaking pulley/belt, intermittent. 1999 Grand Caravan
ecrumb sounds like you have a belt problem still, I've heard that only an expensive Gates belt or factory belt is the only way to go.
Old 03-25-2012, 05:15 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
I agree with James. It does sound like a belt issue. Some of the cheaper belts from places like Autozone and other parts stores are too slick. On a squeaky belt another temporary fix is to use a crayon or something similar. The wax on the belt makes it more sticky and it doesn't slip on the pulleys.
The Following User Says Thank You to Scotty89 For This Useful Post:
jamesslcx (03-25-2012)
Old 06-11-2012, 08:46 PM
shakrepg shakrepg is offline
I had to jump in! I've had the same problem for about two years.I brought a mechanics stethascope (sp?) at Advanced auto(10.89), and found that the tensioner pulley was bad-again! after just 2 years, if not for a tip from a friend, I'd be driving over a cliff by now! I went through everything you have, trying to solve the sqeaking, not much in hot dry weather, but very much in damp rainy weather, and the wd-40-I did it all, it seemed to defy logic, but its quiet now. Good luck!
1999 Grand Caravan 3.8 intermittent shuttering when shifts happyreefer Caravan | Voyager 1 08-20-2011 09:10 PM
1999 grand caravan se 3.3L HEATER Tyson_baker Caravan | Voyager 4 01-24-2011 03:24 PM
1999 Grand Caravan A/C Evaporator Core diagram ecrumb Caravan | Voyager 4 07-12-2010 08:04 PM
1999 Grand Am nanatraci Car Audio 5 06-19-2009 07:00 PM
Tags
1999 , belt , caravan , pulley , squeaking
