Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-22-2012, 08:33 PM
jgl38017 jgl38017 is offline
2000 Suburban hot air only and no cool air
I have a 2000 Suburban which is only blowing hot air from the vents. If I turn the temp selector to cold it still blows hot air. Even when I press the button for AC it still only produces hot air. Any ideas would be most appreciated.
Old 03-23-2012, 07:49 AM
j cAT j cAT is offline
Re: 2000 Suburban hot air only and no cool air
in the duct of the air box directly above the tranny hump is the air temp door blender . this is a stepping motor device that moves the door that varies the air flow across the heater core.
many times this will stick due to debris or the device is failing.
tap on the vent ducting in this area and see if it unsticks. if not remove it and clean the vent ducting. if clean and no operation , then you will need to replace it.
there is no control for heatercore coolant . the coolant constantly flows thru the core inside the air box. changing the flow of air varies temp.
The Following User Says Thank You to j cAT For This Useful Post:
jgl38017 (04-01-2012)
Old 04-01-2012, 02:37 PM
That seems to have fixed it. I removed the shroud and tapped the door blender a few times and it appears to be working now. Not sure how long it will last but at least I have an idea what it is if it comes back.
Thanks again
Old 04-01-2012, 03:50 PM
Thanks again
since thats it then , avoid placing the temp to full hot. do 3/4 hot only on temp control.
3X I have had to do this over a few years now.
2000 Suburban Hot/Cold AC/Heat Switch dkraines Suburban 4 06-11-2006 09:27 PM
How much does a performance exhaust and cool air intake help? Fredrick_NP Engineering/ Technical 8 07-13-2005 11:08 AM
Air only blows cool at idle? MusikMan169 Jimmy 4 07-02-2005 01:23 PM
2000 Suburban...Door panel removal and sub woofer replacement drkshadow C/K 0 07-06-2004 10:24 PM
