Old 03-22-2012, 01:48 AM
doctorhrdware doctorhrdware is offline
Hub assy Bearing
2000 Silverado 5.3 l V8 has around 168k miles. The front hub assy, can you just replace the bearing, or do you have to replace the complete hub assembly. The driver's side bearing just started to make noise.
Old 03-22-2012, 06:24 AM
ColoradoSilverado ColoradoSilverado is offline
Re: Hub assy Bearing
You have to replace the whole hub, it's not that hard just have to get the right size socket, don't remember what size it is though...
Bert
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
The Following User Says Thank You to ColoradoSilverado For This Useful Post:
doctorhrdware (03-22-2012)
Old 03-22-2012, 08:30 AM
j cAT j cAT is offline
only use a timken hub assy. this is made in the USA. cost is about 180.oo ea. autozone.
I tried some from 1AAUTO that came from china and it failed in 10,ooomi. I had 2yr warrantee so I got my cash back, minus 13.oo ship.
cost was 90.oo ea. if you live in the rust belt you will need a 5lb hammer and a heavy duty chissel. be careful or you will break the heat shield.
torque the big nut to 155ft lbs. loosen nut before starting/jacking.
The Following User Says Thank You to j cAT For This Useful Post:
Old 03-22-2012, 02:42 PM
I apprecite the answers to my questions. I have always use timken bearings when ever possible. The heat sheilds are toast so I will be replacing both sides. I have also replaced the front CV Half Shaft assembly both sides. So taking it apart should not be that hard.
front bearing - new or junkyard replacement? gijmcd Sonata 5 02-15-2010 07:15 PM
96 caravan rear hub assy removal jenkir Caravan | Voyager 2 08-25-2007 07:30 AM
93 JGC wheel bearing/hub assy rob87035 Grand Cherokee | Grand Cherokee SRT8 1 02-25-2007 11:31 AM
Bearing hub assy R/R rufousray Cavalier 4 06-19-2006 06:05 PM
Removing wheel/speed sensor from Hub Assy bwhuot2 Galant 0 03-26-2005 11:13 PM
