Old 03-20-2012, 04:00 PM
bbullsj bbullsj is offline
97 k1500 wont engage back into park
i have a 97 k1500 pickup and have been haiving problems gettit to shift back into park. it comes out of park fine and through the other gears but i have a lot of trouble getting it back into park. i really have to slam it into park. this just started a monthy ago and has been getting worse to when it takes a dozen tries before itll go in. it does have a 3in body lift but i have not had any trouble with it until now. any ideas? i thought maybe it was just linkage but its a 4l60e so isnt it electrical? maybe a part that the shifter connects to?
Old 03-20-2012, 08:46 PM
j cAT j cAT is offline
Re: 97 k1500 wont engage back into park
I believe its the shift cable. you should see the bracket on the driver side with a rubber boot..
sometimes this bracket gets bent . sometimes when fluid/pan drop is done.
Old 03-21-2012, 11:20 AM
777stickman 777stickman is offline
1st thing is to disconnect the shifter cable at the tranny and see what happens. Post back results and we'll go from there.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-22-2012, 11:59 AM
well i have someone shift through the gears while i was underneath it. it seems that the rubber or plastic bushing in the metal bracket that the cable runs through is loose in the bracket. so when i shift into drive it pushes it back and then prevents me from putting it back into park. ill either replace the "bushing" or just toss a hose clamp on it for now to hold it in the bracket so it cant slip out. thank for the help
95 k1500 wont shift into 2nd.. found melted solenoids coreman30 C/K 9 01-18-2011 05:24 PM
95 k1500 4x4 wont engage scottinachevy C/K 1 11-02-2009 06:15 PM
94 Chevy K1500 4wd wont engage steveninspokane C/K 3 11-19-2005 02:30 AM
back seat wont "snap" back into place fraulein100 General Discussions 2 09-06-2005 08:36 AM
