Old 03-19-2012, 01:09 AM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Mass Air SensoR
Morning
What are the symptoms of you mass air sensor failing? or When do you know when it is time to have your MAS replaced?
Old 03-21-2012, 02:11 PM
Girly VR-4 Girly VR-4 is offline
Re: Mass Air SensoR
they really don't go bad very often. what is the problem your car is having?
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 03-22-2012, 01:21 AM
ricebike ricebike is offline
Re: Mass Air SensoR
when you have a 1996+ model, it should set off a OBD II code...
sometimes your vehicle may go into "limp mode"
http://www.obd-codes.com/p0100
what that website didn't mention is when some people use those re-cleanable filters and re-oil it too much, then the excess coats the wire in the MAFs & you'll need to clean it with an electrical cleaner
Old 03-23-2012, 10:58 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Mass Air SensoR
Even pre 96 cars can get an CEL from a faulty MAS and not all faulty MAS cause a CEL.
Engine cuts at 4K like its rev limited. 72mino HHR 8 04-27-2012 03:26 PM
