Go Back   Automotive Forums Car Chat > Chevrolet > HHR
Old 03-18-2012, 10:21 PM
72mino 72mino is offline
Engine cuts at 4K like its rev limited.
I have an 06 HHR with the 2.2 ecotech and auto tranny, 145K, but the engine or at least the coil pack is from an 03 cavalier. I just bought it at an auction. The intake hose is missing (from the fender to the air box), but I don't see where that would have a major affect on it. It usually won't start on the 1st try, but does on the 2nd, misses for a few seconds, then idles smooth. It drives fine as long as you don't get on it.
As I said in the title it won't rev over 4000, but I found out by accident that if the MAF is unplugged it will, so I replaced it and it didn't change anything. It is also only getting about 17MPG around town, which seems low to me.
I thought it might be a blown head gasket, but I did a compression leak down test on each cylinder and the only leakage I have is a little by the rings I hear in the oil fill hole. I also did a compression test and got 185-195 psi in all cylinders.
My code reader won't read the codes on it for some reason, but Advance Auto's will. There weren't any codes that seemed relevant, but I reset them by unhooking the batter after I checked compression, & leak down. I will go back in the morning and have them check again to see what came back and post them.
Any suggestions would be appreciated.
Dustin
Old 03-19-2012, 08:15 AM
maxwedge maxwedge is offline
A990 racer
Re: Engine cuts at 4K like its rev limited.
Do a full scan and look at fuel trims and sensor inputs, btw you know of course if in neutral it will not rev over 4k.
Old 03-19-2012, 10:07 AM
Thanks for the info MazWedge.
I didn't know that it shouldn't be able to rev over 4K in Neutral, but it does the same in gear too, unless the MAF is unplugged. I'll have the codes checked today, but the fuel trims and sensor inputs will probably have to wait until Saturday.
Dustin
Old 03-19-2012, 11:46 AM
The code is P0171 lean condition bank 1 (of course there is only one bank). I checked fuel pressure and it is only showing 30psi at idle and drops down to 0 in just a few seconds, so it sounds like its time for a fuel pump, but I will check for 12+ volts at the pump first.
Dustin
Old 03-19-2012, 01:32 PM
I googled it and found my exact problem, and it is my fuel pump. Here's a link to the thread. http://www.chevyhhr.net/forums/archi...p/t-31407.html
Dustin
Old 03-19-2012, 06:58 PM
A990 racer
Don't change the pump without checking fuel pressure first.
Old 03-20-2012, 02:27 AM
34 psi and drops to 0 in about 3 seconds.
Old 03-20-2012, 08:08 AM
A990 racer
34 seems low, check the specs, also should not drop off that fast.
Old 04-27-2012, 03:26 PM
Replaced fuel pump about a month ago. It runs great and MPG is in the mid 20's instead of mid teens. Now it has 60 psi.
2000 blazer cuts out, possible Rev limiter problem?? HELP hunter4ever12 Blazer 4 02-12-2012 05:17 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
Engine sounding like its a diesel???????????? J.S. Grand Prix 4 05-23-2007 07:18 PM
gst feels like hits rev limiter at 4500-5000 critter07gt Eclipse Problem Diagnosis 3 02-12-2007 10:46 PM
Engine feels like its bogging down...? bluelude84 Prelude 6 04-20-2006 12:49 AM
Tags
air , flow , limiter , mass , rev
