Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-18-2012, 09:01 PM
barks507 barks507 is offline
2 problems with heat controls
I recently figured out that the actuator for controlling temp has gone bad. I've done research and have figured out where it is and how to fix it. While I was checking it out I noticed another broken piece. It is a piece of nylon that hooks into a metal arm that is connected to a diaphragm. I figure this is why I also cannot select where the air flow is going. I can't find any info on how to replace that part. It doesn't look as easy to get to as the actuator. I tried to pry the white nylon piece off but, no go. Any one done this before?
Old 03-27-2012, 08:05 AM
Re: 2 problems with heat controls
I took my temperature control actuator out and had it apart. Also had an electrician at my work check little motor inside. Everything seems fine. When I plug it in it goes to 1 side and will not go back when temp is changed at dial.
I'm thinking it may be something wrong with the dial now.
Any thoughts? If so, what's my next step. Is it easy to get behind dials?
2000 LS NO POWER TO AC/HEAT controller Cassious Regal 1 12-17-2009 06:29 PM
Problem with heat / ac control cjocher Suburban 0 05-22-2009 04:01 PM
problem with vr berlina cruise control and climate control Stewie1085 Commodore/VS/VT/VX 0 10-22-2008 03:22 AM
problem with heating in 1995 Isuzu Rodeo vitaly1995 Rodeo | Passport | MU 4 12-14-2005 12:41 PM
Problem with heat and it's the coldest of the year.. Sid Daley Swift 3 02-09-2005 09:29 PM
