| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Welding seams
Hi guys,
I have a question. How do i scratch welding seams on exhausts from bikes. I saw somebody used putty thru a syringe or masking. I have done the masking before, but i think with putty i can become a better result. What kind of putty can i use and what do i use to thin the putty with? Thanks in advance. Best regards, Lesley |
Re: Welding seams
I've seen a sheet of photo etch weld seams somewhere, can't remember where though
.gpz900ra7.
MY 1:1 toy
Re: Welding seams
ive seen it done with tamiya liquid putty. personally for 1:24 models i use superglue to make a bead, & for 1:12 i use very thin half round styrene, glue on, then get a knife (like a putty knife) heat up the tip of the knife with a lighter then make marks & squish the half round styrene until your happy with the result
It's Not wheather you Win or Lose, its how you look while you play the Game |
Re: Welding seams
Hobby Design is the company that produce the sheet of photo etch weld seams;
http://www.hobbydesign.com.cn/class_list.asp?id=44 Look for HD02-0145 gpz900ra7.
MY 1:1 toy
Re: Welding seams
Aber makes pe weld seems also. The best putty to use would be a 2 part epoxy putty like muliput or tamiya. That way you can roll it out to size you want.
Re: Welding seams
Another option is Archer 3D resin weld decals. An exhaust might be too tight a bend for them though.
Re: Welding seams
Hi guys,
Thanks for the all the info. I already ordered the etch weld from hobby design and i'll let you know when i have used them. Best regards, Lesley |
Re: Welding seams
My
![]() ![]() Also, you can use Plastistruct to make the styrene a little more malleable to make the weld marks vs heating the knife. I think the Plasitstruct lets you sculpt more than the heat lets you. Superglue (thick superglue not the thin stuff) is a great idea too if you can make sure you don't get it too wide where you end up with a bead that is 1" in scale. Excellent ideas Ashman! Quote:
Re: Welding seams
White PVA glue works well too. Just paint it on in joined up 'blobs' for great results.
If you naff it up, it washes off with water so you can try again. Roy. |
