Go Back   Automotive Forums Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 03-29-2010, 06:51 PM
sepandee sepandee is offline
To weld or not to weld
My sister damaged my brand new ralliart the other day:http://www.youtube.com/watch?v=tFaFk2k2PzY
I took it to several body shops, and finally settled on one. They're going to replace the skin. Now, forgive me, I don't know much about auto body parts and the process, but when I asked about the possibility of rust (because my rust module's warranty will be voided once anything is done to the door), he said he's seen some really good results with some glue. So instead of welding the skin to the door... frame? (hope I'm saying this right!), they glue it so there's glue in between the two metals and it won't rust.
Sounds about right? Or no?
Old 10-22-2011, 07:04 PM
bodymanhelper bodymanhelper is offline
Re: To weld or not to weld
Hi
Where i work at we weld the skin to frame at all 4 corners.
Old 10-22-2011, 07:21 PM
LearnAutoBody's Avatar
LearnAutoBody LearnAutoBody is offline
Auto Body Mod
Like bodymanhelper said, there may be a few welds, but for the most part, skins are bonded with adhesive or glue. It does help with corrosion and holds well. To test it, we have glued to metal tabs together and pulled it on a frame machine to determine how much pressure it would take to pull it apart. Every test, the metal rips or tears, while the adhesive never fails. However, extreme heat can cause the adhesive to lose adhesion, but this should be a problem.
Old 10-22-2011, 07:32 PM
Hi
We do run a bead all the way around on the frame for crrrosion protection before we put the skin on.
Old 02-18-2012, 01:16 PM
RRummel RRummel is offline
Banned
Thanks for the feedback. Yes, SendMail works on regular RSS channels but still does not work with Webscrape apart from when the channel was first created.There doesnt seem to be anything in any of the logs.Im thinking that maybe Webscrape doesnt trigger an event everytime it updates - any thoughts?I appreciate the help
