Old 03-17-2012, 10:28 PM
tacosoldier tacosoldier is offline
Harmonic Balancer Puller question
I'm currently working on replacing the Crankshaft Position Sensor. I rented the puller from Autozone. I got the retainer bolt off, then went to use the rented tool just to find out that the bolts in the kit were too big. I pretty ticked off cause I had to travel 50 miles to get this tool. The local auto stores didnt have any on hand. Does anyone know what size bolts is required?
Old 03-27-2012, 01:36 PM
TerminalCommuter TerminalCommuter is offline
Re: Harmonic Balancer Puller question
EDIT: what year is your intrigue?
The crankshaft position sensor is above the startor, and the camshaft position sensor is under the coolant tank. No-need to pull the harmonic balancer.
Old 03-29-2012, 06:09 PM
Not on this Intrigue, mine is a '99 with a 3800 series 2 engine. It's behind the pulley.
Old 03-30-2012, 11:19 AM
Tech II Tech II is offline
Go to your local hardware store and pick up some long bolts......I'm guessing they are 8mm or 10mm, not sure......
Get a variety of sizes to try, and then bring them back and get three of the ones that fit.....
Please help! Harmonic balancer question 31928 SC300/SC400/SC430/Soarer 2 01-01-2010 09:06 PM
How do i tell if I have a bad Harmonic Balancer shanea1 Engineering/ Technical 2 10-05-2009 05:13 PM
99 pontiac granprix harmonic balancer puller bolts asosa1 Grand Prix 3 10-03-2006 06:51 AM
