Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 03-16-2012, 06:54 AM
big white bufflo big white bufflo is offline
ignition referanc singal car run stalls restarts
im working on a 95 dohc run scan i get po401 egr code and a mill 011 ignition ref signal car runs live data shows 4 to 5 deg flux in timeing car stalls hot and cold and restarts could not fine valve to run fuel pressure check i suspect cam or crank sensor any imput help full
Old 03-17-2012, 08:46 PM
jamesslcx jamesslcx is offline
Re: ignition referanc singal car run stalls restarts
bufflo, do you think that fluctuation in timing is enough to make it stall? I have seen problems with the egr cause these cars to stall. Any other symptoms? Has the car been maintained well? I wonder about the fuel pressure though.
96 grand am see 2.4 stalls from idle after restarting when warm john murman Grand AM 2 11-29-2010 05:55 AM
93 lesabre runs rough and stalling pigeonkiller LeSabre 4 01-10-2010 06:30 PM
Car Starts then stalls and POP! lixar420 Venture 21 01-09-2010 03:30 PM
Car starts, stalls, will not restart. NeedhelpIn661 Taurus | Taurus Wagon 1 12-18-2009 07:02 AM
Stalling/ReStarting problem wx5tvs Caravan | Voyager 9 09-14-2005 07:33 PM
