Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 03-15-2012, 06:11 PM
pete 65 pete 65 is offline
sebring 2.7 overheats
hi
i have a 2002 sebring conv. overheats waterpump is working t-stat,checks out as good,radiator has flow.wont over heat at idle
thanks pete
Old 03-16-2012, 06:07 PM
Supersnc Supersnc is offline
Re: sebring 2.7 overheats
Have you checked your engine cooling fans? If the fan isn't mmoving enough air, obviously the engine will not cool
The Following User Says Thank You to Supersnc For This Useful Post:
jamesslcx (03-17-2012)
Old 03-16-2012, 06:16 PM
Yes fans work, cap is new, water pump has 10,000 miles on it. It is moving fluid. New thermostat. Radiator has flow.
Does anyone know the flow of the coolant ? Has to come out of the bottom hose in to the radiator , because of the location of the thermostat , right ?
Thanks Pete
Old 03-17-2012, 08:31 PM
jamesslcx jamesslcx is offline
Usually when one overheats while driving and everything else checks out it possibly may not have enough airflow coming in so, Have you checked for obstructions in front of the radiator or a missing air dam? Also you said you have flow but is the flow of coolant unrestricted as in no coolant blockages anywhere in the system?
Old 03-18-2012, 09:38 AM
No restrIctions I have not flushed the system yet
At wits end
Pete
Old 03-18-2012, 05:50 PM
Pete, how does it run? CEL on? I would probably try a coolant flush, also a timing problem can cause overheating. Good luck and I always thought those cars were sharp.
P0172 p0175 v6 2.7 galaxsat Sebring | Sebring Coupe | Convertible 1 11-24-2011 10:38 AM
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
2002 Sebring lx, 2.7 cooling problems remington2985 Sebring | Sebring Coupe | Convertible 2 04-12-2010 10:20 AM
2004 Sebring LXi, 2.7, passenger window goes down only...? miki75 Sebring | Sebring Coupe | Convertible 5 04-05-2010 08:57 AM
