Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 10-18-2011, 05:35 PM
galaxsat galaxsat is offline
P0172 p0175 v6 2.7
I bought this convertible a couple of months ago as my daughter's first car and have been working on it ever since. After a major rebuild due to rod knock, it was time to tackle the "little" remaining problems. First off was P0601 code (PCM checksum), which I ordered from a refurb outfit in south Florida. It took 3 to get one that didn't kick the same code. Now I am getting P0172 and P0175 (rich on both banks), as well as P0700 & P0740 (TCC not locking).
The car runs great. I tore it back down again today enough to check fuel system, etc ...no leaky injectors, pressure is normal, couldn't find any vacuum leaks, MAP is clean and operational. EGR seems OK, no apparent exhaust leaks or intake air restrictions. I'm stumped, and considering taking it to the dreaded dealer for diagnosis.
Freeze-frame data gathered just running the car in the garage after reassembly:
DTC for which Freeze Frame was Stored: P0172
Fuel System 1 Status: Closed Loop
Fuel System 2 Status: Closed Loop
Calculated LOAD Value: 6.67 %
Engine Coolant Temp: 127.40 °F
Short Term Fuel Trim - Bank 1: -25.00 %
Long Term Fuel Trim - Bank 1: -25.00 %
Short Term Fuel Trim - Bank 2: -18.75 %
Long Term Fuel Trim - Bank 2: -25.00 %
Intake Manifold Absolute Pressure 11.55 inHg
Engine RPM 704.00 rpm
Vehicle Speed Sensor 0.00 mph
While I doubt the tranny codes are at all related, I am wondering if the refurb PCM company even programmed / flashed it, and that may be what is causing the fuel mixture codes?? Any suggestions are more than welcome!
Old 11-24-2011, 10:38 AM
Re: P0172 p0175 v6 2.7 [SOLVED!]
Update...for anyone else that might benefit from this post. After running the gamut of tests, including fuel pressure and leakdown, which were both perfect, I have finally solved this problem. Basically, I was down to the PCM having a too long a baseline injector pulse width, or wrong injectors. I tore it down enough to get the part numbers off the injectors last weekend, and as it turns out, they were for a 2003-2004 2.7 rather than a 2002. I got lucky for a change and scored a set of OEM refurbs on sale on eBay for $100, swapped them this morning and instantly my STFT went way positive. Letting it run for 10 minutes brought the LTFT up to 0% where it belongs.
As for the tranny codes, a new torque converter solved that. I think the clutch plate had been dimpled by someone using flywheel bolts that were too long.
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
'00 civic codes p1399 and p0172 hyperz17 '96-'00 Civic 0 05-19-2010 08:00 AM
96 GMC Jimmy Help....O2 Sensor?? corhey88 Jimmy 1 02-15-2010 06:24 PM
swap a 2.7 engine in 2001 intrepid whith 2.7 2004 seabring gignac02 Intrepid 2 01-19-2006 08:17 AM
Tags
2.7 , chrysler , p0172 , p0175 , sebring
