Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 03-14-2012, 05:03 PM
msvregan msvregan is offline
transmission p1788
2000 ls v8 sport shifts normally exept while shifting into 2nd, it kind of pops out but then locks then shifts normally. thanks for any help.
Old 03-14-2012, 09:28 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: transmission p1788
What does the tachometer do when the transmission seems to "pop out"?
-Rod
Old 03-14-2012, 09:36 PM
whats up rod thanx for reply. To be honest its pretty quick so it doesnt rev its like a burp in the shift. Trans shop pulled code and test drove it and said need a rebuild.
Old 03-14-2012, 09:49 PM
joegr joegr is offline
So, they say that your transmission needs to be rebuilt because of a code that indicates an electrical fault (open circuit) with the pressure control solenoid? This must be one of those AAMCO (All Automatics Must Come Out) type chain places.
The worst case is that the solenoid assembly may have to be replaced. The best case is that you have a cut wire or bad connector somewhere.
Old 03-14-2012, 10:07 PM
Yea, thatswhat i thought. When it happened i was sst and i thought it was 3rd gear but they said 2nd. The shop used to be cottman but now its privately owned by a guy who used to work for cottman. Anyway still shifts normal exept for 3rd, im pretty sure its not 2nd it shifts smooth. At 2000 rpm 1st to 2nd it doesnt really drop off.
Old 03-23-2012, 05:06 PM
Cannot get selenoid pack out. All bolts removed but electrical connector with o rings will not come out. Appreciate any help.
Old 03-23-2012, 05:42 PM
You took out the bolt that runs through the connector, right?
Old 03-23-2012, 05:50 PM
No. Where is the bolt located, is the connector on top side of trans? thanx for helping
Old 03-23-2012, 07:14 PM
Yes, and you have to get it all the way back in and bolted tight when you install the new one, otherwise you'll have flaky problems.
Old 07-03-2012, 08:30 AM
Hi guys. i just posted another thread about overheating and was browsing open threads and saw that i never updated my post on transmission problem. So here it is, the trans shop was wrong no rebuild needed. After replacing selenoid pack no more problems. thanx for all the help much appreciated.
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
2003 s10 transmission problems burk4200 Problem Diagnosis 6 03-30-2009 07:07 PM
Transmission woes 99 in 09 Taurus | Taurus Wagon 1 02-19-2009 04:16 PM
