Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 03-12-2012, 04:29 PM
doughert0 doughert0 is offline
'94 GTO Check engine false alarm?
'94 Lebaron GTO - My check engine light goes on intermittently, sometimes stays on, sometimes goes right back off. No symtoms. Diagnostic code 55 - basically no code. Anyone else have this problem"
Old 03-12-2012, 07:10 PM
94LebConv3La604 94LebConv3La604 is offline
Re: '94 GTO Check engine false alarm?
Have you tried to retrieve codes while the CEL is lit?
Old 03-13-2012, 01:28 PM
jamesslcx jamesslcx is offline
Probably a false code or maybe an forthcoming problem but I wouldn't worry too much. Just make sure all electrical connections especially grounds are clean and tight. I would also run some fuel system cleaner in it occasionally. Good luck.
Old 03-18-2012, 02:58 PM
Sounds like a good idea, but the light is too intermittent. Either a false alarm or, as suggested by another, a bad ground. If the latter, something is going to quit.
Old 03-18-2012, 05:45 PM
Doughert0, how is it running now? Any changes? Let us know and good luck.
Old 03-18-2012, 06:29 PM
I think your idea that I have a bad ground has merit. My radiator fan has been running intermittently - should run in town when temp goes over (I think) 230, or when the AC is running. However I have had some near overheats because the fan wouldn't run. Pulled the assembly to get the shroud number so I could order a new fan, but when I put it back in, worked fine. Drove around about an hour, fan came on every time it should, including when the temp gage reached third tick.
Right now, everything is working fine, but I suspect a bad ground somewhere, which will probably rear up again. Also, the bad ground could be internally in the fan motor. I'll try wringing the circuit tomorrow, but have little hope until the problem re-surfaces.
I'll post when I find something out.
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
Passport Check engine & check trans blainemetfan Rodeo | Passport | MU 10 10-10-2006 02:26 PM
'94 Camry -Check Engine Light, but no error codes lyonkster Camry/Camry Hybrid/Vista 4 01-16-2006 05:42 PM
Checking check engine light codes schneids714 F Series 5 02-05-2005 10:13 PM
Check transmission, check engine kplusten Trooper | SLX | Bighorn | Wizard 2 06-07-2004 02:15 PM
