Go Back   Automotive Forums Car Chat > Kia > Spectra | Cerato | Forte | Mentor
Spectra | Cerato | Forte | Mentor Couple 4 and 5 door models.
Old 03-11-2012, 08:17 PM
MinnieRolltide MinnieRolltide is offline
Question Shifting Rear End
I have a 2004 Kia Spectra I purchased 2-3 months ago. It drives good on smooth surfaces, no issues. However when I hit uneven surface or pot hole the back end seems to shift from side to side for about 1-2 seconds then recovers. I looked under it and didn't see anything broken. One tire looked worn so replaced it. Was told it needed new struts, so replaced all 4 struts and mounts, but it still does this same shaking when you hit a bump or uneven surface. I jacked it up and tried to wiggle the wheels, but nothing loose. Didn't see any brake dragging. It doesn it even if you don't have brakes on. Any thoughts?
Old 03-17-2012, 12:41 PM
rhandwor rhandwor is offline
Re: Shifting Rear End
Did you try moving the rear wheels in and out?
Old 03-17-2012, 06:35 PM
Yes.
As it turned out had a tire that looked good, but apparently had a busted belt or something because when I moved it the problem followed. So replaced the tire and now am back in business.
Thanks
Car moved 10ft in park when I was rear-ended. planetm Cars in General 1 07-07-2011 04:10 PM
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
1995 Dodge 1500 rear end problems alley30577 Ram Pickup | Ram SRT10 2 02-19-2010 09:37 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 09:10 AM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
