Old 03-11-2012, 04:33 PM
Skrilla75 Skrilla75 is offline
2000 Taurus trans concerns
The trans hesitates a little between 1st and 2nd only the first time youi starts driving the car and only appears to do it that time.After that the car runs perfect no issues whatsoever even if I open her up a little shifts nice just the first shift after being started.There is trans fluid in the car.What could it be
24V v6 model SE
Old 03-11-2012, 10:22 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 Taurus trans concerns
You mention there is transmission fluid in the car, is the fluid in good shape at at the correct level when checked with the engine warm and the car idling in Park?
Are you sure it's a transmission hesitation and not a misfire or something else?
-Rod
Old 03-12-2012, 02:10 AM
No its no misfire its a hesitation doesnt really slip as much as shifts late.Ill check the fluid one more time.It does have a little leak but granted if it has fluid at the time it should be good.
Old 03-12-2012, 06:34 AM
shorod's Avatar
SHO No Mo
Only if the majority of the fluid it has is in good condition and has the correct additive package. If the fluid is burned, degraded, or the wrong type for the transmission it can still cause shifting concerns, even when filled to the proper level.
-Rod
Taurus X Concerns? alk1752 Taurus | Taurus Wagon 2 12-29-2008 03:19 AM
will the transmission in a 95 taurus work in a 2000 ford taurus bj_the_king Taurus | Taurus Wagon 1 11-10-2006 07:49 PM
85 shift fork trans concern eastwildlife Corvette 0 09-09-2005 07:06 PM
2000 Trooper Alternator Concerns LEM Trooper | SLX | Bighorn | Wizard 3 04-27-2005 05:53 AM
