Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-11-2012, 02:14 PM
gregory914 gregory914 is offline
0 Compression #2 Cylinder
Thinking about buying an '02 Grand Cherokee Limited (4.7 V8) with 90K miles. Runs but makes puffing sound like a blown head gasket. the dealer took it to a corner garage and their diagnosis is "0 psi on #2 cyl. due to timing chain skip". That's all I got!
It starts and runs relatively smooth and only makes that puff puff sound. My questions are;
-do these engines skip time with the chain still attached and the motor running.
-are they a "conflict" motor.
-could it be a stuck valve or head gasket.
-trying to determine if it's worth pursuing and the worst case situation.
Has anyone had any similar issues with one of these motors, if so, what was the problem.
Thanks for any input
Old 03-12-2012, 08:10 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 0 Compression #2 Cylinder
I suggest that you walk away from this one. Timing chains do not skip where only one cylinder would be affected and with 90K miles it is almost unheard of. Also with "0" compression there is something more going on here like a dropped or damaged valve, bad valve seat or even a damaged cam shaft. Don't waste your money as this one will only cost you much more in the long run.
Old 03-12-2012, 08:45 AM
Thanks for the advise. However, this Jeep is in excellent condition other than the motor issues and I was thinking worst case I'd replace the motor with junkyard unit for about $1600. I think I can buy this for around $4K, so for a $6K investment I've got a low mileage one owner Grand Cherokee Ltd.
Old 03-12-2012, 02:09 PM
Pontiac Guy
If you can purchase the vehicle for that price it would be worth replacing the engine. Of course ever wonder why he has it listed so cheap?
Old 03-16-2012, 02:46 AM
hundahunta hundahunta is offline
dropped seat very common, remove the valve cover you'll probably see the rocker arm lying in the head....
98 Monte Carlo Z34 low compression cylinder EastDawg737 Monte Carlo 0 01-30-2008 08:43 AM
4 cylinder to 6 cylinder Venusjems Wrangler 2 12-06-2006 07:09 PM
Can a 4,6,8 cylinder Tachometer be set for a 3 cylinder? DOCTORBILL Metro 11 11-28-2006 08:17 AM
4 cylinder to 6 cylinder 4line Tiburon | Tuscani 2 11-23-2006 09:09 AM
4 cylinder vs. 6 cylinder Jono1289 Wrangler 3 11-21-2005 10:12 AM
