Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-09-2012, 12:08 PM
pkupman1 pkupman1 is offline
Cam Size
how do you determine the right cam versus the right carbureator for a 350 chevy engine. I want a little more power that the standard 350 but not overpowered.
Old 03-09-2012, 09:59 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Cam Size
There's a bunch of stuff that you have to take into account here ... tire size, axle ratio, vehicle weight, desired powerband, exhaust, and intake all figure into the equation.
What kind of car, and what style of driving?
I replaced the engine on my Caprice less than a month ago. The new engine has a Howards 180315-10 grind cam in it, that seems to be good for the application. This cam has a 110 degree LSA, 116 degree intake centerline, .465/.470" lift and 209 intake 215 exhaust duration @ .050". Stock intake w/ 4bbl E4ME carb, stock style exhaust manifolds with dual exhaust, 3600 lb car with 3:08:1 axle ratio and 28" diameter tires. So far, I am not upset with its performance at all.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-10-2012, 06:42 AM
Re: Cam Size
Thanks that is a lot to consider. I would be putting it in a 1970 Chevy CST-10 truck, with a 350 4 bolt main with a set of double hump heads 2.02/1.60 with either a 600/650 carburetor, intake to be determined, 235/15 tires, everything else would be standard.
Old 03-11-2012, 09:43 AM
maxwedge maxwedge is offline
A990 racer
Re: Cam Size
call a cam grinder like Comp cams their tech guys will set you up with the right grind.
couple questions about 1979 trans am... what size cam/and aftermarket heads? nuclearkrieg Engine and Transmission 1 01-29-2009 01:23 AM
Cam Sizing SikNingStang Performance 9 10-29-2005 12:11 PM
single overhead cam or dual overhead cam? david m Focus | C Max 3 12-12-2004 07:16 PM
which cam is the intake cam? wickedplastikman Integra 11 10-12-2004 04:15 PM
Installing Cams. Cam timing???? boosted k20 Integra 2 08-15-2004 12:49 AM
