Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 01-27-2009, 03:05 PM
nuclearkrieg nuclearkrieg is offline
couple questions about 1979 trans am... what size cam/and aftermarket heads?
Hey just had a question for you guys.
What is the biggest size cam you can put in a 6.6 403 Olds engine without having to mess with the pistons and such?
and what are the best after market heads you can get.
Old 01-29-2009, 01:23 AM
Scraped Knuckles Scraped Knuckles is offline
Re: couple questions about 1979 trans am... what size cam/and aftermarket heads?
Check out www.dickmillerracing.com/Engine_page.htm and www.mondellotwister.com for Oldsmobile performance parts and crate engines. Also you should post your question in the Olds forum. Stock compression was quite low at 7.7-1 and you might consider buying a 455 olds to build up as it would be cheaper and more powerful. Plus the 455 will bolt in with your current engine mounts.
