Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-08-2012, 12:32 PM
knilive2 knilive2 is offline
98 malibu wheel n front drive ruff
i jack the front up . the drivers wheel shake side to side a little. i change the hub, the outer tie rod end . n still the same thing. what could be wrong . the wheel sounds like it going to fall off
Old 03-08-2012, 02:37 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 98 malibu wheel n front drive ruff
Look at the lower ball joint when you shake it. Thats probably where the play is.
Old 03-10-2012, 09:55 PM
Joe W Joe W is offline
If the lower ball joint is not moving a likely culprit is the wheel bearing. Hope this helps!
Old 03-11-2012, 08:52 AM
When I was changing the hub and the tie rod end I've notice that the boot on the ball was dry rotted and looks kinda ruff. I really didn't pay it any mind at first but I'm thinking you hit it right on the nose. Lol feeling kinda like a rookie for someone that been working on this car since 98 lol. A $17 fix, today I will install one. Thanks for the help and I will update
Old 03-11-2012, 02:05 PM
Tech II Tech II is offline
Was it the 12/6 o'clock position that moved, or the 9/3, or both?
If you changed the hub/bearing assembly and the outer tie rod, and the BJ is ok, then it is probably the inner tie rod...if the inner tie rod is ok, then check the bushings to the lower control arm....
Changing a front wheel drive 3.8 to rear wheel simmondj General Discussion 3 09-03-2008 10:49 AM
Drive Wheels: longitudinal front-engine/rear-wheel drive McLin Thunderbird 3 01-21-2008 02:48 AM
What is better front wheel drive or rear wheel drive? auto600 Engineering/ Technical 1 05-03-2007 11:31 AM
1 wheel front tire drive? babalon1 Cavalier 4 12-30-2005 03:37 PM
Rear Wheel Drive Or Front Wheel Drive? Cereal_Killer Avenger 1 06-22-2005 10:00 PM
