Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-06-2012, 11:03 PM
pete63 pete63 is offline
power steering hose ??
blew a power steering hose I think it's the return line it's the one with the foil heat shield. The fluids comming out from the end of the foil cover.
Heres what I need to know:
1) Which line is it on the steering column the front or the back connection?
2) Does anyone know what tool I'll need to loosen the nut
It's pretty rusted so I was thinking about cutting the line near the nut and using a socket to get it off, then a crowsfoot wrench to put the new one on. Unless someone knows an easier way to get it off. It's a pretty tight spot.
any help with this is appreciated.
thanks
Old 03-07-2012, 11:07 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: power steering hose ??
Pretty sure it's the lower hose on the steering gear, follow the hose to make sure. Its a 18mm fitting at the gear. It helps some to drop the back of the cradle down for more room. A wrech and/or a crow foot will be needed.
The Following User Says Thank You to gmtech1 For This Useful Post:
pete63 (03-07-2012)
Old 04-01-2012, 03:58 PM
Sorry I didn't post back sooner.
Well I got it fixed ended up replacing both since I was under there.
What a pain it was until I bought one of these from Harbour Freight.
www.harborfreight.com/14-and-38-drive-x-14-38-double-head-flex-ratchet-wrench-67994.html
The Craftsman wrenches would only turn the nut about 1/16" and the ratchet with a crowfoot wrench was to thick to fit.
That low profile flex head ratchet with a crowfoot wrench was the ticket. I was done in no time with it. One of the best investments I've made, just need to get a better brand, but it worked.
I would suggest anyone changing one of these hoses to get one of the ratchets. Just made the job so much easier.
Power Steering hose/Pressure Hose burijon Intrigue 6 11-30-2018 11:18 AM
power steering hose geech Lumina 0 04-02-2004 11:42 AM
91 taurus power steering hose blows impoverishedcook Taurus | Taurus Wagon 1 03-10-2004 01:12 PM
Power steering hoses bad too? skotmxpx Blazer 0 02-23-2004 09:58 AM
power steering hose on 92 Escort crawfish Escort 2 01-20-2004 09:22 AM
