Old 03-02-2012, 12:52 PM
fastmoney fastmoney is offline
Emission Evap Not ready? Egr cleaned and fixed
2002 olds alero 3400 engine.....I had a code of a p1401 insufficient flow to egr ..Which is most of the time the clogged passage. I took the throttle off an accessed the egr passage. Boy was it clogged with carbon so I cleaned it out thoroughly, which fixed the problem.
I reset the computer I drove it a few days and now all the monitors are ready, except the evap monitor. I have drove a few days highway, street, stop and go etc my tank being half filled etc. And its still not ready. Car has to take emission soon. Its a coincidence because the Alero ac isn't working so it can't be turned on right now.
I ran into a similar problem with a 2000 Monte Carlo the evap wouldn't go to the ready status he had a short somewhere and the ac compressor would work intermittently. The compressor finally worked one day with defrost on and the evap went to ready.
I'm just wondering, I'm sure its other ways for evap to go ready but the ac is the fastest ???
Old 03-02-2012, 01:28 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Emission Evap Not ready? Egr cleaned and fixed
Fast, I did a little research and found that a Tech2 scanner may be need to run what they call "service bay tests" in order to reset your I/M flag for the evap system.
You will have to take it to a dealer in order to have this done. Hope this helps!
Old 03-02-2012, 02:41 PM
Oh wow.. thank you for your help..I will let you know what happens.
Old 03-02-2012, 02:57 PM
jpb53 jpb53 is offline
2001 MY and newer can have 1 monitor incomplete and still test.
http://www.epa.state.il.us/air/vim/faq/obd.html#8
2001 grand prix help needed wont pass emissions bagged98 Grand Prix 9 12-20-2011 05:49 PM
Emission control EVAP canister hose connections dave2001auto Sienna 1 11-06-2011 05:41 PM
EGR cleaning/diagnosing jpar1983 Malibu 7 11-03-2011 12:17 PM
No Code, I/M EGR and Evap not ready. shjd05 Intrigue 0 02-07-2009 05:34 PM
EGR Cleaning -> EGR insuff. flow engine code? mlingk Trooper | SLX | Bighorn | Wizard 7 02-16-2005 11:43 AM
