Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-01-2012, 09:20 AM
Electricflow Electricflow is offline
Clicking Noise Before Starting car
2004 Mitsubishi Eclipse GTS 6 cy 112000 Miles
This problem started after changing the car battery
When I turn the key (just to the spot where the electric systems turn on) there is a series of clicks usually about 3-5 of them. The Noise comes from the engine compartment, some where under the main part of the engine.
The engine starts fine. It seems to run a little rougher, but I was thinking that might have to do with resetting the computer values (I have only driving it 15 miles after battery change) I have yet to go through the resetting procedure inside the manual.
I really would like to know what these clicks mean and weather I need to get the car serviced to avoid future problems...
Please Help ....
Thanks in advance for the help
Old 03-09-2012, 07:07 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Clicking Noise Before Starting car
Welcome to AF
Usually clicking noises are associated with relays turning on and off rapidly. Several things can cause them to do this: Battery thats going bad, or bad connections on the terminals. The relay itself could be going bad, bad grounds, I have even seen a bad alternator cause a relay to click somehow. You need to try and figure out exactly where the noise in coming from to diagnose it further.
I would clean the battery terminals first to rule that out. Check all the grounds going to the battery and the grounds on the engine. Then have the battery and alternator tested since advance or auto zone does that for free. If that doesnt fix it then might want to try testing or replacing the relay.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Rattling/Clicking Sound When Starting Car jcoberly Mustang Problem Diagnosis 0 07-11-2011 09:52 PM
front clicking noise. wheel?? sohcd16 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 10-24-2010 09:53 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 07:25 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 08:44 PM
get a clicking noise when starting flipnjme Caravan | Voyager 2 09-07-2004 05:18 PM
Tags
clicking , engine , piror , start
