Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-26-2012, 05:14 PM
mark4674 mark4674 is offline
01 LS 3.9 hesitates when Floored?
Here is the History so Far,
car started missing- pulled codes got p0308 (water in plug well)
Checked other wells found some oil in a few.
Changed valve cover gaskets, installed new motorcraft plugs (pulled out motorcraft agsp-32F plugs, checked gap on existing plugs .044. Advanced Auto gave me agsp-32FM plugs. Gapped them same as old ones.044. Replaced CoP on cylinder 8 with a new one.
Car ran worse than before, (smelled Horrible),
Decided to reinstall old plugs, Reinstalled checked for oil in wells and all dry so gasket job worked. I did find a loose CoP connector when taking apart. (did not fix the problem tho. Not sure if the plugs are different 32F old- 32FM new. not sure what the M means after the F.
Put everything back together and car is running smooth again. Took for a long drive to make sure everything is OK. When i put the pedel to floor, the car hesitates and surges. Under normal driving conditions the car seems to run fine. (no missing, smooth acceleration, smooth idle). But when i floor it hesitates and surges, but seems fine when normal driving is resumed.
Checked for codes and only pulls up a p1565. From searching other post i find that this is from a bad clock spring. Which i do have to replace (airbag light blinks 3-2, and cruise control is a little whacky.
Will a bad clock spring cause the hesitation when floored?
Any help is greatly appreciated, Thanks
Old 02-26-2012, 08:27 PM
joegr joegr is offline
Re: 01 LS 3.9 hesitates when Floored?
No, it won't.
You need to replace the other seven COPs, and all spark plugs. This time, gap them to the correct gap, 0.041"
(Good COPs would work okay with the slight over gap 0f 0.044" that you set, but older marginal ones wouldn't.)
The Following User Says Thank You to joegr For This Useful Post:
donaldcampbell (06-29-2012)
Old 05-02-2012, 12:01 PM
danielsatur danielsatur is offline
Suspect:
1) Dirty, or bad MAF sensor.
2) Dirty throttle body.
3) Bad air/fuel filter
4) Plugged catalytic converter.
5) fuel pressure
You need plenty of Air, fuel, and exhaust for horse power.
V6 2002 Mustang hesitates when accelerating lcmidas Mustang Problem Diagnosis 1 04-06-2009 09:59 AM
car hesitates when floored,but only at higher rpms jeremytalon92 Eclipse Problem Diagnosis 15 02-21-2008 08:33 PM
3.9 stalls when cold chadwic Ram Pickup | Ram SRT10 4 10-24-2006 07:24 PM
2001 Dakota 3.9 hesitation and missfire 2001Dakota Dakota 1 08-10-2005 08:14 PM
Eagle Talon 92 tsi awd hesitating when flooring it patt101 Off-Topic 4 07-21-2004 01:34 AM
