Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-29-2008, 11:11 AM
jeremytalon92's Avatar
jeremytalon92 jeremytalon92 is offline
car hesitates when floored,but only at higher rpms
every time i floor it and the rpms reach at about 4500 rpms,the car hesitates and chugs.it just started like 3 friggin' days ago. any hints or fix's. my repair manual said it could be vacuum leakage,fouled plugs,clogged fuel filter or injectors.even a tech said leakage! ????????????????????????? opcorn:
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights
Old 01-29-2008, 11:14 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: car hesitates when floored,but only at higher rpms
We cant help you unless we know what car you have.
If its turbo check for boost leaks.
If its NA then do a tune up and see if problem is still there.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-29-2008, 12:02 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Just do a tune up in general no matter what model.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-29-2008, 12:56 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Any indicator lights coming up?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 01-30-2008, 10:31 PM
no lights on , boosted , 92 talon tsi awd
Old 01-30-2008, 10:46 PM
Holset powered 420a
Do a boost leak test and a tune up and see if the problem still exist.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-30-2008, 11:01 PM
how would my car react to a boost leak?
Old 01-30-2008, 11:03 PM
steviek's Avatar
steviek steviek is offline
it would run rich and sputter when boost hits
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-30-2008, 11:27 PM
george536's Avatar
george536 george536 is offline
i would do plugs and wires.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 02-05-2008, 09:35 PM
mydelsol mydelsol is offline
I second the plugs and wires. I had a buddy with the same problem. We swapped his plugs and wires out and problem solved.
1993 del sol s
1990 Eagle Talon Tsi Awd
Old 02-05-2008, 10:26 PM
ned032002's Avatar
ned032002 ned032002 is offline
Mine has a heavy idle surge when at idle (duh!?) and it also hesitates like crazy at about 5k rpms also. I haven't done a boost leak test yet though, would that cause both of my problems? Also at idle I get a CEL until I just tap the gas and it goes away? I'm in the same boat as Jeremy.
Old 02-05-2008, 10:33 PM
Holset powered 420a
I would do a boost leak test first. That should fix most, if not all of your problems.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-07-2008, 11:02 PM
ned032002's Avatar
I've seen some pretty nice boost leak testers on eBay, how hard are they to make? The bonus of buying one of the ones in the link is that you will always have one that does the job.
http://cgi.ebay.com/ebaymotors/ws/eB...204235386&rd=1
Will it work on a small 16G? The description says stock turbo.
Old 02-08-2008, 11:25 PM
i have found the problem,indeed the plugs were bad so i replaced them both.the cylinder number 2 plug was burned until the bar on top dissolved,dont guess the person i bought it from took very good care of it,some times i feel like judo chopping him in the neck for being careless,but thank you for your help everybody
jeremy
Old 02-17-2008, 12:07 AM
ned032002's Avatar
I've searched on how to do a boost leak test and I've found so many different do's and dont's threads that I don't know what to do. I bought the Tester in the link that you see above but I haven't used it yet. What do I need to do to test if I have a boost leak? I know I need to put the one end on the turbo and then pressurize the pipe up to 15 psi or so. Now what do I need to plug and what do I need to unhook to this test. If someone could tell me step by step what to do I can do it.
EDIT: Found VFAQ, I will try to do the test tonight and post my results.
