Old 02-26-2012, 03:10 PM
moliva1568 moliva1568 is offline
overheating question
This is going to seem like a very dumb question but I'm going to risk asking it. My temp gauge isn't working right now. What would be a telltale sign that the vehicle is overheating? I picture smoke coming from the engine and the car being immobilized. Are there any not so obvious signs I should look for? I recently changed a heater control valve and I see today the reservoir isn't at the cold line. I don't see any evidence of the coolant leaking like it was before I changed the valve. Being the paranoid person I am, I'm now thinking blown head gasket and wondering if the car overheated and I didn't pick up on it. I may be jumping the gun but that's my fear. I'm going to check the oil when I can (not driving it now) I looked for bubbles in the radiator which I saw but also wonder if that could be air in the system. The van doesn't seem to be running poor and the only "smoke" is see from the tailpipe is steam at startup. I do get a faint smell of coolant in the cabin but it's not constant.
Thanks
The Following User Says Thank You to moliva1568 For This Useful Post:
carleasing (02-27-2012)
Old 02-27-2012, 12:25 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: overheating question
Obvious signs would be steam coming from the engine compartment. If your engine overheats, the coolant would boil and make big clouds of steam.
There is a chance that mild overheating would occur before the coolant boiling. In that case you should notice reduced power and excessive knocking.
Dragging people kicking and screaming into the enlightenment.
The Following User Says Thank You to curtis73 For This Useful Post:
Old 02-27-2012, 01:28 PM
Well I checked the oil and it does seem to be thin and discolored. What I thought was steam does appear to be smoke and the coolant keeps dropping but not on the floor. So this will be an expensive lesson learned. Anything else I should replace while the head gasket is being done?
Old 02-27-2012, 01:33 PM
mannasugar mannasugar is offline
Hi,
It would be quite simple & inexpensive to replace the temperature sensor and/ or gauge. It will be much more expensive to overheat your engine and replace it....
Old 02-27-2012, 01:49 PM
That I'm definitely going to change. Was going to do that anyway and unfortunately this happened before I could.
Old 02-27-2012, 11:07 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
If you are having a shop do the head gaskets, have them send the heads out to a machine shop to check for cracks and warps.
It is a VERY good idea to change the valve seals. For many years, older small block chevy V8's were known for leaking seals which led to modest oil burning. I am not sure if your year was so affected, but if it is, its much easier to change the seals with the heads off.
Finally, it may be an idea to go for rebuilt heads, which includes resurfaced valves and seats, decent guides, new seals and a check for cracks and warps, so you know everything on them is good.
Old 02-28-2012, 07:39 AM
I'm still going to do a compression test and block test once I can get to autozone to rent the tools. I just pulled the dipstick again hoping my eyes deceived me in that area. The oil looked normal. It's been sitting since sun. If coolant is mixing in the oil, would the oil on the dipstick still be indicative of that days later?
Old 02-28-2012, 08:50 AM
If getting rebuilt heads is what I do, any tips on what to look for? I came upon a site called headsonly.com aka cylinder heads international which had "decent" prices.
Old 02-28-2012, 09:01 PM
MagicRat's Avatar
Rebuild your actual heads so long as no cracks are found. Do not go for trade-ins or swaps imho
There are a bewildering number of small block heads made over the decades. Many will physically bolt on to your engine but may have subtle differences that may affect performance. Rebuilding your actual heads ensures you have the correct ones. Most major urban centers have engine rebuild shops that can do a set of heads for you.
Also, coolant mixed in the oil will make the oil look like a chocolate milkshake for a long time. If the engine oil looks like oil after running the engine briefly and not a Dairy Queen product you don't have significant amounts of coolant in the oil.
Old 02-29-2012, 12:27 AM
jonnyeverything jonnyeverything is offline
im pretty sure coolant goes to the bottom of the pan
Old 02-29-2012, 09:19 AM
I'm looking for a shop to take the van to. Any suggestions on what to look for? A small independent garage or service center like Firestone?
Thanks
Old 03-04-2012, 03:00 PM
thankfully it wasn't the head gasket. The shop i took it to said it was the heater core and replaced it. I may have to bring it back though. The heat only seems to get "hot" when i'm driving as opposed to idling. any idea what that may be?
thanks
Old 03-05-2012, 12:17 AM
in addition to the temp gauge not working, the oil gauge goes bonkers. check it out
Both are while idling and the first video i put it into D
Old 04-04-2012, 04:29 PM
Tesla220's Avatar
Tesla220 Tesla220 is offline
thanks
When one does a heater core job it is sometimes hard to initially get all the air out of the cooling system. This leads to not having heat at idle. Just top off the coolant level and keep an eye on it for a few days. Top off at the radiator only when the engine is cold. It may take a few days to get all the air out.
Chance favors the prepared mind
Old 04-04-2012, 05:55 PM
FishFind FishFind is offline
One Hot Shot
yeah I would guess you have air trapped in the system.
Overheating Question neurosis Alero 2 07-11-2005 10:04 AM
another overheating question Liberato Aurora 2 02-05-2005 09:29 PM
General Overheating question markme123 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 5 08-27-2004 03:24 AM
Overheating Question joemathews Off-Topic 34 07-02-2004 08:18 PM
