Old 02-25-2012, 03:48 PM
bradleypa bradleypa is offline
97 chevy s10 blazer fluid in the 4wd actuator vac line
Ok I replaced the actuator and the cable leading down to the front axle. All was working well for about a month and now it's not. the actuator seems to be struggling to engage the front axle. I pulled off the vac line and noticed the actuator has a good amount of tranny fluid in it. Next thing I noticed the amount of effort to pull the cable using pliers is pretty difficult. I read as many threads as I could find about the transfercase switch letting fluid into the vac lines so I'm working on that. but what about that hard pull?
Old 02-25-2012, 08:54 PM
old_master's Avatar
Advisor/Moderator
Re: 97 chevy s10 blazer fluid in the 4wd actuator vac line
There's a fair amount of things that move in the axle housing when engaging the axle, so it does take a fair amount of effort. Parts 7 through 22 are all involved with engaging the axle:
Might be worth while to take it apart and check to be sure.
As for the fluid in the lines and actuator.... The seals in the transfer case vacuum switch are leaking. Transmission fluid is sucked past the transmission rear seal, and the transfer case front seal. Fluid level in the transmission decreases, fluid level in the transfer case increases, the fluid migrates into the HVAC & 4WD vacuum system, (lines, actuators, mode switch, reservoir etc). Transmission fluid deteroirates rubber rather quickly and all of those parts contain rubber. Both the HVAC & the 4WD vacuum systems must be cleaned out. If you're lucky, the transmission and transfer case seals will seal as designed after the vacuum is removed.
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
bradleypa (02-26-2012)
Old 02-26-2012, 07:47 AM
Ok I will let you all know what the outcome is.
Thanks!
In Christ
bradleypa
what transmission is in the chevy s10 blazer with a vortec v6? gnknt Problem Diagnosis 7 02-01-2010 07:34 PM
WTB : S10 Blazer 4x4 4.3L Hard Fuel Line dew88 Classifieds 1 07-21-2009 06:17 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
92 S10 Blazer Stuck in 4WD please help jpakers Problem Diagnosis 4 12-04-2008 05:28 PM
how do i replace the 4wd actuator on 97 silverado drweather C/K 2 08-25-2005 08:56 PM
